Honda Civic CRX D16 D16Y7 Connecting Rod
Fit for: Honda Civic CX DX EX LX HX RT Si Value 1.6L/CRX Si 1.6L; Quantity: one set (4 Pieces), Center length: 137.00mm, Big end diameter: 48.00mm, Small end diameter: 19.00mm Big end width: 22.80mm, Small end width: 18.20mm
Forged SAE 4340 Chrome Moly Steel for the highest strength and durability, dedicated for Racing£¬Full 3D Designed and processed by CNC machine; All big and small ends are finished with SUNNEN honing machine;
Precision alignment sleeves positively locate the rod cap, maintaining big end bore size and eliminating cap walk; 100% X-rayed, sonic tested and magnafluxed, Multi-stage heat treated, Shot peened to relieve stress; Come with the bronzed bushing suitable for the floating piston pin; Weight tolerance each set rods: +/- 1g;
Come with ARP2000 bolts(contact us for extra cost for upgrading to ARP L19 bolts); Full covered by Manufacture Limited lifetime warranty
Link: [url="http://www.amazon.com/dp/B00RYGE6SA"]http://www.amazon.com/dp/B00RYGE6SA[/url]
