MX5 Turbo
Kaj si mislite o tem avtomobilu ?
Pomoje je to ena prava mala zverina, s pospeski okol 4.5sec do 100km/h
Razmisljam o tem, da bi bila to ena dobra varianta na nabavit. Obstaja pa menda tudi servis v Velenju, kjer ti namonitrajo turbo za mx-5.
http://www.mobile.de/cgi-bin/search.pl? ... =1&x=0&y=0
Hej Tunner, a bi znal naredit kaksen body-kit za tako mx-5 ? Recimo podaljske odbijacev in pragove, ali pa nove odbijace - kit na podlagi starih ?
CRX VTi '93
Men tuki nobene slikce ne odpre!
Jah... ze prodano (ni cudno, saj je bila ugodna cena)
CRX VTi '93
cruiser: Ja s turbino avto res postane zverina. Velenjski servis je dober, tudi jaz vozim moj avto tja. Mogoce bi jaz tudi vgradil turbino, samo je bolj pametno sparat za S2000 :-)
Tu je en opisal voznjo z MX-5ko, ki ima neke vrste turbo:
I don't have a turbo but a Jackson Racing Supercharger. Based on the M45 Eaton Roots supercharger I am at a maximum boost of 11 psi. I had to change a lot of other items on the car to make it relyably strong. New clutch (Kevlar), 1.8 Torsen differential, New engine management ECU (Link mark I ECU) , Intercooler, Toyota Supra Turbo fuel injectors ,aux. high flow pressure fuel pump..... My MX-5 now has 197 DIN horsepower and a maximum torque of 238 Nm/4500rpm (Dyno tested). To give you an idea of how flat the torque graph is , my MX-5 already has 200 Nm at 2000rpm !!! As you can imagine ,it is quite fast and a joy to drive ! This is the kind of power it should have had out of the show-room. The MX-5 in standard form, just lacks the power, to make it a "real fun" car !It sure has surprised many people when they saw such a fast MX-5 pulling away from them !
Dobro opisano . Tole more bit res igracka!!
"Pedal To The Metal"
Civic HB VTi '97
